Salta al contenuto principale
Dai un'occhiata a queste guide per trovare informazioni sulla riparazione e sullo smontaggio della tua macchina da cucire.
20 Domande Visualizza tutte
Bernina 830e service manual (electronic/embroidery/sewing machine)
I need help finding a Bernina 830e service manual. (This is for the electronic/embroidery/sewing machine, not the manual for the 830/831 record that is already listed on this site.) I live waaaaay too far away to get to a dealer for repairs, updates, etc. ''No, my problems/answers are neither found on the Bernina web site nor in the Instruction manual. I have the 250+ page Instruction manual; I need the Service/Repair Manual. Will pay for the correct manual.''
Sorry to scream (above). :-) Just want to save everyone’s time in helping me find the corect manual. For some reason, Bernina has 2 models named 830, which makes it easy to find the incorrect manual. Thanks.
Questa è una buona domanda?
Punteggio 0
1 Commento
Still looking for the Bernina B830 service manual, this is for an 8-series machine. I wish they would update that firmware…hint hint Bernina?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you email Bernina directly and ask them they may be able to help.
https://www.berninamanuals.com don’t appear to have service manuals for the 830 range which is unfortunate. I would suggest contacting them however, as they are probably your best shot: Info@LRBservices.net
I do have a copy of the “Adjustment Manual” which I think applies to all the variants of the 830 model. It may be what you are after, I’m not sure.
Bernina-830-Record-Service-Man.pdf
I hope this helps :)
Punteggio 3
1 Commento:
One hundred thank you’s!!!!!!!
It is the most helpful thing I’ve seen since I bought the ill behaved 830 12 years ago. You’re great!!!
da
Aggiungi la tua risposta
Tee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 993
