Salta al contenuto principale
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 Domande Visualizza tutte
Having problem with my controller
I bought two new controllers after using it for a week, then my controllers will not turn on or charge anymore.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Are you sure that's not a cable issue?
da
I have thy diffent cables it didnt work:(
da
Aggiungi un commento
1 Risposta
Maybe your PS4 is not sending the required voltage through the USB port, try to use a smartphone charger on your controllers.
Punteggio 0
3 Commenti:
Hi!
If a smartphone charger (5V) is not working. Then try on another PS4. It’s weird that 2 brand new controllers are experiencing the same issues. And are you able to test with something like this: https://www.beboncool.com/wp-content/upl... ?
da
I don't think that trying another PS4 could work this far, the common components here which have a direct relation with the controllers are the cable and the PS4 USB port, I don't think a cable could harm the controller but the USB port can, overvoltage will easily damage the controller and in order to ignore that lead you need to mesure the USB output voltage.
If everything seems to be correct then you have to disassemble the controllers for further investigation, you should start by checking the battery.
da
I've tried that too, ussing my smartphone charger.
da
Aggiungi la tua risposta
Almuzani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 68
