Salta al contenuto principale
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
SSD upgrade causes iMac 2015 to freeze after minutes of use
I upgrade my iMac to an SSD and once it boots up after minutes during use it will freeze completely and will not be responsive to anything. I have enabled TRIM settings but find that it is still doing the same thing. What comes next?
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you tell us more details on which model iMac you have as well as the exact SSD you used (make, model and interface SATA or PCI).
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sorry actually I figured it out apparently I just needed to do a complete wipe of all data and reinstall the OS in recovery mode and now everything is good !
Punteggio 1
Aggiungi la tua risposta
Jerrell Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 160
