Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1200 Domande Visualizza tutte
My iPhone x has poor wifi/bluetooth connection
After doing a housing replacement on my iPhone x, the wifi and bluetooth have very poor range. I can only connect to wifi within only a few feet of the router and on connect to bluetooth devices that are basically inches away from the phone. I have replaced the wifi/bluetooth module already and no change. Any ideas?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Did You Connect WIFI And Bluetooth Antennas Correctly?
Double Check Them
da
Could you be more specific on which antenna pad you are referencing?
da
Aggiungi un commento
1 Risposta
The weak signal means the antenna and antinna pad not connect properly check it bro.
Punteggio 0
Aggiungi la tua risposta
Matt Weg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,305
