Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
220 Domande Visualizza tutte
How long to charge new battery and LCD before iPad will turn on?
Hi all
I've left a new battery to charge since 4.45 pm yesterday and the iPad still doesn't turn on.The connector to the lcd was very hard to locate but I finally managed to do it (but did I?)
Is it possible to connect it to the socket ‘wrong' I wonder?
On initial examination of both the socket and the connector,I didn't see any pins stuck in either.
As far as I can gather,I should be able to test it without having to put it all back together or won't it work if not all back in place and sealed again?
Update (09/17/2019)
Thanks for your reply Ben,
Re-seating the connector has done the trick.
Thanks also for mentioning disconcerting the battery first.
I hadn't thought of that,but yea - I do so on my bike or car,and same applies with any electronic circuits!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Have you verified that the replacement LCD is not for the Mini 1 and is for the Mini 2?
Those LCDs have a very subtle difference which you can see from the bottom of the LCD display assembly. At the bottom there are two metal rectangle covers that are soldered to the back of the screen.
On the mini 2 this will be smaller than a Mini 1 version. So a quick way to see if you got the right screen if the old screen has the same size metal as the new screen. If it’s not the same you’ll notice the difference at a glance.
Try reseating the display cable, this one sometimes is not plugged in fully on one side. Remember to always have the battery unplugged when unplugging or plugging in the display cable. If the battery is flat it should at least show you the low battery icon.
If not there is a problem with either the display or the power going into the iPad, hopefully not a board-level problem.
Punteggio 1
1 Commento:
Thanks Ben,after reseating the display cable it now seems to work.
da
Aggiungi la tua risposta
EAMONN COLLEY sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 35
