Salta al contenuto principale
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Domande Visualizza tutte
Domanda Chiusa
no backlight on screen
I am having a problem with the brightness on my display .There is a image on the screen when the laptop i completely open .When I close the laptop to about 15 degrees or so before completely closing the screen brightness comes back on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Replace the inverter cable that seems to be be broken in the PB hinge. You still have a backlight connection when moving the lid but sooner or later you'll lose it when the cable will be completely separated. Do the repair as soon as you can cause there's a risk to damage the logic board if the cable short in the hinge. Don't move to much the lid when the PB is powered until the cable is replaced.
Punteggio 2
Check the cable. the cable was pinched.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,808
