Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
No wifi but bluetooth OK?
Hello - I have an IPhone 6 S plus, the wifi is greyed out but the Bluetooth turns on and can pick up BL devices. In Settings / General /About a wifi address can be seen.
Have replaced wifi modules and antennas - the symptoms don’t match the classic wifi IC failure and the phone is not getting hot.
Any ideas?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I thought someone had answered this.
Why is my WI-FI greyed out?
1.       No power getting to the Wi-Fi chip
2.       Oxidised pads under the WI-FI chip
3.       Brocken trace under WI-FI chip
4.       Damaged WI-FI chip
5.       WI-FI chip not communicating with the CPU
If you have blue tooth you can rule out number 1.
Punteggio 1
First re-hot the WI-FI chip and check.That must be WI-FI module faulty because both have enviled in same chip.
Remember that you need to unbing WI-FI with Nand by removing.
Punteggio 0
Aggiungi la tua risposta
Louis Kaldmaa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 156
