Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
Vibration doesnt work accept home button
Vibration is only working in home button feedback but not in other cases like the system wide haptic feedback or vibration on ringtone.
i severely broke my phone & had to change the casing by placing my motherboard onto another iphone 8 plus casing which was icloud locked.
After that I’m facing 4 problems
  1. Haptic feedback works only on home button (tried changing setting and restore iphone)
# No airpod prompt when I open the lid, cant connect it instantly, gets disconnected often
  1. low wifi range
  2. Most often only 2 bars in cellular network indicator.
  3. can anyone suggest me a fix?
  4. thanks in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
  1. low wifi range
These two more then likely caused by incorrect assemble of the antennas
you need to back track on your work
Cavo flessibile Antenna Diversity Wi-Fi dell'iPhone 8 Plus
Punteggio 0
1 Commento:
Thanks @edigitcom
And about taptic feedback?
da
Swap the vibrator over so its using the original.
Punteggio 0
Aggiungi la tua risposta
Nazmul Hossain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 314
