Controller work alone with USB cable only
PS4 working alone with USB cable only
When you have the USB connected to the controller, it stars working on its own. Already switched cable and controller and does not solve. What will it be? Very strange problem…
Questa è una buona domanda?
Punteggio
0
Not that strange at all. Connected to USB unit receives power via whatever it's connected to. Your game controller relies on battery power when not connected to USB. Battery and/or unit charging circuit is most likely problem.
da prop man
@propman the problem is that the controller only starts pressing buttons alone when the cable is connected (I left the video link for sample). Without the cable works perfectly
da Joao
Ahhh......try checking the USB connector for debris, clean contacts with applicable contact cleaner or 90% or higher concentration isopropyl alcohol. Open PS4 and do a visual of the USB for any looseness in the connector itself, loose connections, loose terminals, cold/cracked solder joints, blown components such as capacitors with domed tops, scorch marks, burnt or exploded components.
da prop man
@propman I'll try, thank you.
da Joao
