Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
467 Domande Visualizza tutte
My MacBook backlight is not working after water damage
I spilled some water on my Macbook, the computer worked well for a while, and suddenly the screen turned black. It never lighted up again.
Now it works perfectly with an external monitor. When I put a flash through the apple logo I can see the mouse cursor. What would be the problem and how should I fix it? Thanks in advance.
BTW, the display looks like this when I flash through the apple logo.
https://imgur.com/Q6iJWZ5
Here are some images when I opened it up. Any help would be appreciated.
https://imgur.com/a/4Ti6mjY
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your motherboard needs a Liquid Damage Treatment, can be a simple fuse or a Chip on the Motherboard. Somebody has to check it internally and do a diagnostic, or remove the back and take a picture we can help you.
Punteggio 1
2 Commenti:
Thank you for the reply! Here are some images. Which side should I focus on?
da
Hi, i think is to late but here is the fuse location Backlight fuse and wled driver location on logical board a1398 2014 you can check it with a multimeter.
da
Aggiungi la tua risposta
Junwei Sun sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 189
