Trans Shift Sensor Location 4 cylinder
I have a 1998 4 cylinder Honda Accord…
The year and a half ago the car started to give just started to not go into drive it was just started you know it just was just a little hard so I stop driving it right away and then I got ill and yada yada so no I want to find the: “Trans Shift Sensor" so I can clean it out, transfer comes in the top of the oil comes in the,clean and put it back together and see if that's the issue…can't find anything with not schematics not a video not anything for a 4 cylinder so I take the everything off on the right hand side cuz everything's for a 6 cylinder and if it was a 6 cylinder it be a piece of cake and I would already be done so I take off everything and for the life of me I cannot see any thing that has just four bolt cuz it's a 4-cylinder so I'm looking everywhere I take off the air filter I take off that hose at golf the new no filter holder there's nothing there's nothing there with four bolts there's nothing there not one thing has four bolts on it to indicate that it would be a 4-cylinder anyting like the 6-cylinder cap do you know what I'm saying to the trans shift cylinder sensor so where the !&&* is it located I cannot believe what they only made one 4-cylinder Honda in the whole world I mean there was more recalls on this car than Carter has liver pills well whoever you are you probably don't even know what that means so let's just put it this way there was a lot of recalls it was only owned by one person a doctor and nobody else ever sat in the car it's meant but I know it's not the toll it's not the whole trans I've blown more trances and had more bought more cars that were pieces of dirt and people you often you know anyway off my soapbox I just need to know where the !&&* it's located at so I can just clean this thing out and I think that that's all it is is that it's dirty…
the trans fluid is crystal clear my oil is clear as the the the day I had it changed I'm meticulous about all of that I mean even the rubber on it. There's nothing wrong with it it didn't even crack there's a little rust and there was a little oxidation I took care of that but other than that there's nothing wrong with the car so it needs to the tires need just a little air in them but I cannot find that sensor for all the gold in China can you please tell me or give me something just show me where it's at just tell me where it's at just right down to me just give me directions to where it's at send me a picture of where it's at I just give me a visual that's all I need and I got I got the rest I got the number to 10 ratchets all set to go I got the I've already WD-40 everything I've already got the brake cleaner to clean out the screens I'm good to go I just can't find the thing to fix it so please help me thank you very much for listening reading my texts on the soapbox channel…
Questa è una buona domanda?
