Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
I need help can a 2009 MacBook logic board fit into 2007 MacBook
Hello I have a 2007 MacBook a1181 black but I was just wondering can I swap the motherboard I bought a 2009 MacBook logic board and I have the other logic board that's 2007 out of the MacBook but is it possible to get the 2009 motherboard and use it in a 2007 MacBook
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Which 2009 MacBook is it? If it’s the A1181, it should work fine. If it’s the A1342, absolutely not.
Punteggio 0
6 Commenti:
The A1181 has a square camera while the A1342 has a round camera. That's the easiest way to tell them apart
da
What can I do with the motherboard then I only have just the motherboard
da
@jj14378 I suppose you could check the ports, if there's two audio jacks then you have an A1181 board (compatible).
Also don't mind if it doesn't have the charging port, it's a seperate component you can take off your existing board and put on the replacement
da
Update - just realized the 2009 boards have slightly different antenna connector locations. Well crap. I'm still really unsure if the antennas will work (so why accept my answer?)
da
@ngs765 well what does accept mean and I didn't mean that sorry u want me to unaccept answer? I didn't mean to do that sorry
da
Mostra 1 altro commento
Aggiungi la tua risposta
Kenneth shawn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 127
