Salta al contenuto principale
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
replace used touch+ glass screen
Can I replace touch screen + glass
to: iPad air 2, 16 GB wifi+4G - white color
destination iPad is A1567. I think It’s the same display, what do you think?
Color, memory size and cell/wifi wouldn't be dependent objects.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Every air 2 uses the same display. As long as you are experienced in removing Air 2 glass without cracking the glass it should work fine.
Punteggio 5
3 Commenti:
With "removing Air 2 glass", are you referencing to only glass or to glass+touchscreen?
It's too hard to remove touch screen from glass ! I know It's necessary expensive and professional tools to join them again. I'm saying to replace the part which composed by both objects.
da
@rickyleroy I'm sure @benjamen50 referred to the glass+touch assembly that is troublesome enough to be removed without damaging it. It will take lots of care, patience and right tools. Wish you luck :)
da
I meant in terms of removing the whole screen assembly from the iPad housing.
Separating the glass from the LCD display is not what I meant.
Glass will sometimes inevitably have to be cracked if the housing is bent in some way that stops the screen from coming out after separating adhesive.
da
Aggiungi la tua risposta
Riccardo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 149
