Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
new battery went from charging problems to not detected
I just installed a new battery, which went smooth. After the install I performed the battery calibration procedure. After the initial discharge/recharge, during the discharge the battery jumped form 70% to 7% instantly after removing the power.
I ran the cycle a few more times, only to have the battery charge drop faster and faster. Finally OSX says it does not detect the batter. I pulled the back off and checked the connections. All looks correct.
Seems I have a defective battery. What recourse do I have?
Update (08/24/2019)
I reopened the case, unplugged the batter, replugged — then the battery was detected
Now the battery is detected both when on power and off
But, upon each reboot either the mbp things the battery is missing or discharged. Plugin and and it boots. After boot it shows the correct charge.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Barry Kaplan what exact model is your MBP? where did you get the battery from?
da
15' mid 2015
battery from ifixit
da
It looks like we got something trending here with the 2015 MBP . I think it is time to investigate a little deeper.
da
Aggiungi un commento
1 Risposta
Your best bet is to replace the battery or send the macbook into Apple for repair.
It could be a motherboard issue. replace or repair the motherboard
Some replacement batteries: https://www.ebay.com.au/sch/i.html?_from...
SOme new motherboards: https://www.ebay.com.au/sch/i.html?_from...
Your welcome!
Punteggio 0
Aggiungi la tua risposta
Barry Kaplan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 44
