Salta al contenuto principale
The Logitech G700s is a wireless gaming mouse that connects to a computer using a USB wireless receiver. The mouse has 12 programmable buttons, and has a DPI of 200-8200
I got a new mouse and it wont scroll
I changed the settings but it still wont work.
Questa è una buona domanda?
Punteggio 1
1 Commento:
If you haven't already I would download the Logitech software associated with the G700 then check the key-binds on it. My Razer Naga had the same problem, but fixing the key-binds fixed it. If it doesn't work I would recommend contacting Logitech.
da
Aggiungi un commento
1 Risposta
The scroll wheel rotates inside a transparent plastic piece. Remove and clean the transparent plastic piece with alcohol, both sides. The optical sensors infrared light needs to cross the two windows on the plastic piece and the wheel. If the plastic is dirty, the scroll wheel won't work. The dirt comes inside easy from the wheel. Make sure that the tiny slots inside the wheel are clean too, they look like bicycle wheel spokes.
Punteggio 0
Aggiungi la tua risposta
rose simmer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 273
