Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Trying to update it to windows 10 using boot camp
After the install finishes it flashes and doesn’t stop until I turn it off then back on then it says no bootable device please insert and press any key when usb drive with windows 7 on it is in please help
Questa è una buona domanda?
Punteggio 0
1 Commento:
Did you try pressing the "option key" while trying to boot from your usb?
https://www.macworld.co.uk/how-to/mac/wh...
BTW, just so there is no confusion, the usb needs to be bootable and not just have a Windows 7 ISO (or whatever format) file copied to it. If the usb is not bootable, the computer won't boot even if you can try booting from the option key; you will receive the same error message as before.
da
Aggiungi un commento
1 Risposta
Is the USB bootable? (Not just iso/dmg just dumped on)?
Maybe also check the version, in case the Macbook is 32 bit and your installer is 64.
Punteggio 0
Aggiungi la tua risposta
Jen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 51
