Salta al contenuto principale
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Can you get a sata to logic board adapter?
i see there is space for a 2nd hard drive in the mac mini mid 2011 but what about the cable you need for the motherboard?
Questa è una buona domanda?
Punteggio 0
1 Commento
but how to get this cable? any Part Number available?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Wait a month and there will be knock offs of the Apple cable. Check with OWC as they will probably have it first.
UPDATE
Here's my answer on this from a previous question:
You can get power this way :
http://eshop.macsales.com/item/Micro%20A...
I see a second data port on the logic board in the teardown. The flex cable for the hard drive in the 2010 machine is Apple Part # 076-1360. I could not find a picture of it but there's a very good chance this will work. http://www.myservice.com/store/076-1360-...
Punteggio 2
It is an Apple proprietary cable, and the only one that will currently work is the Apple one. So, if you plan to add the second drive you need to get a second Apple proprietary cable.
Punteggio 0
look around... part#922-9560
It is for 2010 model, but also works on 2011... see youtube for step by step instructions
Punteggio 0
Aggiungi la tua risposta
bryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,517
