Salta al contenuto principale
A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
Why is gasoline coming out of air filter?
I have a Troybilt TB635 EC. Recently I replaced primer bulb, fuel lines, and carburetor. I double checked that the three lines from primer bulb are correct and that there are no leaks where they connect to bulb or carb. However, when I press primer bulb about 5-6 times, gasoline will start coming out of the air filter port. Need help with this one please.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thank you very much!!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You may have already done this but here is what I would do in this case. My initial guess would be the gasket in between the air filter housing and the carburetor. There is typically a separate port or hole in the gasket that leads directly to the primer.
  • Take the air filter cover off and remove the air filter.
  • Press the primer bulb a few times until you see where the gasoline is coming from.
  • If you don’t see where it is coming from, then trace the gasoline back to its origin.
Punteggio 1
Aggiungi la tua risposta
Eric Hine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,890
