Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Trackpad not working but keyboard is
I have a 13” 2015 MacBook pro and the trackpad stopped working but the keyboard is working fine. Could it be the ribbon cable or the trackpad itselt?
Tried resetting all kinds of things but did not help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
I would start with the cable as it can be damaged by grit and pressure from the bottom cover and battery MacBook Pro 13" Retina (Early 2015) Trackpad Cable
It’s also possible the trackpad damaged. I have had to replace a few as people tend to spray cleaner directly on the case and the cleaner can drip into the gap between the case and the trackpad and works its way into the sensor sandwich damaging it MacBook Pro 13" Retina (Early 2015) Trackpad.
Immagine MacBook Pro 13" Retina (Early 2015) Trackpad
Prodotto
$54.99
Immagine MacBook Pro 13" Retina (Early 2015) Trackpad Cable
Prodotto
$9.99
Punteggio 1
2 Commenti:
Sensor sandwich! :)
da
@kadan - Take a look at the Magic Trackpad Teardown
And here's a better view of the sensor grid within it Sensor Array from the Magic Mouse. Unlike the mouse its flat and the connections are on the edge to the logic board.
da
Before replacing the trackpad, make sure to check if it’s the SMC. Use this link.
Punteggio 0
Aggiungi la tua risposta
nugety sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 159
