Salta al contenuto principale
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
81 Domande Visualizza tutte
Screws stuck in motherboard
I can’t remove the screws from the motherboard of the DS, and they’ve started to strip. Anybody have any tips that I can try? I’ve already attempted the rubber band technique, and it hasn’t worked out.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Vishal
One trick I used to use when stripping small screws is to carve a straight line into the top and take it out with a flat-head screw driver. you can use any Dremel kit with a pointy bit to carve your line or just grind the top totally off. Here’s a cheap one from harbor freight tools:
https://www.harborfreight.com/Rotary-Too...
Best of luck!
Punteggio 0
Aggiungi la tua risposta
Vishal Seenivasan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 86
