Need to bypass BIOS password.
I have a Toshiba Satellite C675-s7322 That I bought at an estate auction, and there is a BIOS password? I have tried everything I can think of to bypass it. Any ideas?
Questa è una buona domanda?
There is no way to get past the Win7 password into an account.
It is possible to get into a WIN7 computer and make a new account.
try:
on Windows 7 , use F2 on cold start to go to “bootup options”, select
-Safe Boot with DOS command window, then in
the DOS window that should appear, type in
Net user administrator /active:yes {Enter}
then restart the computer, you should now see the hidden
account “administrator” login icon which does NOT need a
password, just click to enter . It is an Administrator level
account which will allow you to CREATE A NEW
Windows USER ACCOUNT of new naming, via Control
Panel / User Accounts / Create Account. If you set it
for Password access, be sure to write down the password somewhere !
BE SURE to give the new account full administrator privileges/access.
I usually make two new full Administrator Access Level accounts,
both password protected.
Exit and restart ; check to make sure you can actually
sign in to your new account(s) . (login to one, then use “Switch User”)
Open a DOS window , type in
Net user administrator /active:no {Enter}
Restart computer; your “invisible” administrator account
login icon should now have disappeared again !
BUT don’t try getting rid of an existing account that you
do not have the password for it, Windows
will want the account password in order to do that .
Shhh, don’t tell anyone !
grumpylumpy
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 486
