Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Why isnt the lid locking in
The lid on my washer isn't working
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Lamont Brown  most commonly cause is a bad lid switch. I suggest you check it by applying a jumper. If your washer functions with the jumpers you know you have a bad switch and will need to replace it. Let us know the exact model number for your washer so we can try to assist you further.
Punteggio 1
Aggiungi la tua risposta
Lamont Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 55
