Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel giugno 2017, questo MacBook Pro ha processori Kaby Lake fino a Core i7 da 3,5 GHz con Turbo Boost fino a 4.0 GHz.
276 Domande Visualizza tutte
Why won’t my laptop charge?
My laptop shut down (low battery) and when I try to charge it (tried to wait for 30 min) it only shows the low battery screen with the connect to power symbol. Charger kept sparkling when put into socket, plastic not melted but metal prongs slightly melted (edge part a bit rough). Is the problem with my charger?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Are you using the original charger and USB-C cable that came with your system?
da
Aggiungi un commento
1 Risposta
Hello,
I’d advice you to try to use a different charger and see what happens. Meanwhile, try to move the charger adapter around and see if it starts to charge it. If you get the computer to start charging try to do SMC reset and PRAM reset and let us know what happens.
Cheers!
Punteggio 0
Aggiungi la tua risposta
bianca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 66
