Salta al contenuto principale
Repair guides and disassembly information for Wileyfox smartphones.
removing battery on swift 2 +
the tear down is on you tube, but the battery removal from the face is done by using thin sheets of plastic sprayed with a liquid which is not identified in the video, it looks like water but may not be something electrically non-conductive
does anyone have a clue to this liquid please ?. thank you. Ben Littlewood.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
@beng0plo looks like its needed to loosen the adhesive strips. This iFixit Adhesive Remover an some of those Plastic Cards should work perfect for this.
Immagine Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172
Prodotto
Plastic Cards
$2.99
Immagine Soften adhesive to make prying and separating electronics components easier.
Prodotto
$19.99
Punteggio 3
1 Commento:
Many thanks for your help. I have ordered the kit, and will advise you how I get on thanks again. Ben.
da
Aggiungi la tua risposta
ben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 682
