Salta al contenuto principale
La saldatura è un metodo di connessione di due pezzi di metallo sciogliendo un metallo d'apporto fra di essi. Ci sono molti tipi di saldature, ma questo articolo è stato scritto per insegnarti le basi della saldatura elettrica.
Warm/cool white dual LED strip parallel wiring advice
Hi Guys,
I have bought a double row LED strip featuring one row of cool white and one warm white LEDs. I am intending to build a grow case for my carnivorous plants.
The case has 4 shelves and each shelf has 4 strips of a dual row (warm & cool white) rigid LED strip. Each strip uses 8W meaning each shelf will use 32W. Times 4 the whole cabinet will draw 128W
I have bought the following transformer:
Aluminum Shell 12V 300W Rain Proof Transformer Outdoor LED Power Supply Driver
I am wondering if I should wire the strips in parallel or in series. Each strip has two negatives and one positive. I was intending to wire each shelf in series then combine all the the cables into one which will be wired into the transformer. Would this work?? I have tried to find videos on wiring this type of strip, but I cannot find anything at all. Any video I could find is on flexible strips with one positive and one negative connection. Also what thickness of wire should I use? Any help is massively appreciated!
Nadja
Photos attached!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
1️⃣ Series or parallel?
  • Series: Current flows through one strip after another. Not recommended for 12V LED strips, because each strip requires 12V. If you wire in series, the voltage needs to add up (e.g., 4 strips × 12V = 48V), which your 12V power supply cannot provide.
  • Parallel: Each strip receives 12V directly from the power supply. This is the correct method for your setup.
💡 Conclusion: Wire all strips in parallel.
2️⃣ How to wire in parallel
  • Each strip has 2 negative lines (for warm & cool) and 1 positive line.
  • Connect all positive lines of one shelf together, and do the same for all negative lines.
  • Do this for each shelf, then connect all 4 shelves in parallel to the 12V power supply.
3️⃣ Wire thickness
Your total power is 128W at 12V. Current I=P/VI = P / V:
  • I = 128W / 12V ≈ 10.7A
Recommended wire:
  • 1.5 mm² (AWG 16) is sufficient for ~11A.
  • For longer runs (>2–3m), use 2.5 mm² to reduce voltage drop.
4️⃣ Extra tips
  • Use twisted or soldered connections with heat shrink or connectors.
  • Avoid shorts between positive and negative wires; 12V at 10–11A can generate heat.
  • Check polarity before powering on.
✅ Summary
  • Series: ❌ Do not do it
  • Parallel: ✔ Correct choice
  • Wire: 1.5–2.5 mm²
  • Total power: 128W at 12V → current ≈ 11A
Punteggio 0
Aggiungi la tua risposta
nadja7765 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 128
