Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
black screen when not charging boot loop when charging
so i dropped my iphone(SE) but it wasnt damaged visibly then it turned off i went to put it to charge and the apple logo popped up then went of this keeps happeneing then i took it out of charge and it became a black screen i searched up how to fix it but most of them is by using a home/lock button which i cant since my home/lock button is broken i need help
Questa è una buona domanda?
Punteggio 1
1 Commento:
As ur home button is broken has the phone been apart before??? Ie is the metal plate that holds the battery connector in place still in the phone, open it up and as a first thing to try check the battery is plugged in ok
da
Aggiungi un commento
1 Risposta
If you don't see a battery icon after you plug in your Iphone then the issue could be with your screen. As you have mentioned that you have dropped your Iphone so your screen might got affected with it.
Punteggio 0
Aggiungi la tua risposta
iriscorreiap sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 57
