Salta al contenuto principale
How do I unplug these connectors?
Hi, very basic question, how do I disconnect these? There's no obvious catch or latch but they're also definitely not unplugging without some kind of release and I need to solder the charging port back on to the board, which I can't access comfortably without unplugging the cables. Thanks in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try googling Molex connectors, click on images and see if any are similar to what you have.
On the top connector, is that a clip lock on the side facing the camera?
Punteggio 0
Aggiungi la tua risposta
Shannon Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 49
