Salta al contenuto principale
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
Input/output errors on external mac formatted hard drive?
I have an external OWC 120 gig hard drive. I use it at work and boot it as the start up drive ( that makes it the blessed system drive when I do). Recently, I noticed that it was getting very slow at work and hanging. I ran Disk Utility on it (when it wasn't the blessed system folder just the external hard drive) but I kept getting errors on it (I forgot what the error said but it wouldn't complete the operation of fixing it).
I decided that I would clone the OWC external hard drive to a Maxtor OneTouch that I had that I haven't used. I partitioned the Maxtor hard drive and then I formatted the hard drive to Macintosh Extended (Journaled). I then cloned the hard drive using Carbon Copy Cloner. It ran for a while and then I got a message from the CCC software saying that I had an output/input problem. It gave me a warning question saying that there was a problem but it would make an attempt to continue. I clicked OK and CCC continued the process.
The cloning was completed today. I ran Disk Utility on the Maxtor hard drive and fixed the permissions on both verify and repair. After clicking the Verify repair and the Repair disk, it both came up green and said that there were no problems.
The question that I have is this: Now that I have cloned the OWC hard drive, can I wipe the OWC hard drive, reformat it and then clone it using the Maxtor hard drive? I mean, I know I can do it but I am wondering what the story is on the bad sectors? Will they get passed when the cloning happens? FYI, I am not getting a click of death from the OWC hard drive.
Thanks in advance for your thoughts on this matter.
Questa è una buona domanda?
Punteggio -1
1 Commento
Mission accomplished on this. I wrote zeros on the external drive and cloned it back from the Maxtor drive. All is well.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I would select the "write zeros" option when you format to map out any bad blocks. I even do this on new drives as the odds of these large drives being error free is slim. These drives are made as cheaply as possible and a certain percentage of error is acceptable to the manufacturers but not to the end user.
Punteggio 1
2 Commenti:
I'm sorry that I didn't think about the write zero thing ahead of time. I could clone the OWC external hard drive on another partition of the Maxtor doing that before I clone again. Do you think that I should? Or should i just go ahead and do what you said above to the OWC drive and send the process in reverse?
da
Try formatting the OWC with the write zeros. The drive might be fine after mapping out.
da
Aggiungi la tua risposta
Yuri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,950
