Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
My iPhone 6s plus freeze when screen locked
Hi i wanna ask what is the damaged component / ic because my 6s plus will freeze after screen locked and will not turn on or charging ( 0 amp ) and i should disconnect batterry and connect it again to turn it on beside that the phone work normally but i think there is some power leak cause the phone discharge fast and it seems not showing the true percentage of the battery cause everytime i reboot it will start from 80% and slowly reduce
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Could be just a bad battery causing that if the battery has never been replaced before. I recommend getting the battery replaced and see how that goes.
Punteggio 0
1 Commento:
No i already changed the battery it must be something has been shorted
da
Aggiungi la tua risposta
azmi muwahid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 41
