Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
Unable to activate screen - iPhone X
I bought a iPhone X and it is stuck on the unable to activate screen with a blue triangle with an exclamation mark.
I have done a restore/update view iTunes but it hasn’t made a difference!
What does the phone need for it to get past this screen??
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Is the IMEI displayed on the screen when you click on the blue (i) symbol on the bottom right of the screen which is located on the lock screen?
If not, this is a baseband fault without the IMEI listed it will not activate. Since it was bought like that, it’s no good to get it repaired as it’s quite expensive ($160>+) for a chance of the phone being iCloud locked after fixing the baseband part.
The little balls that connect the two boards together is probably what is causing the problem, they all need to connect together properly on each ball or else problems like this occur due to a bad connection:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Punteggio 2
2 Commenti:
No imei is shown
da
How about if the IMEI does show?
da
Aggiungi la tua risposta
Rc Noobs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 744
