Salta al contenuto principale
Repair guides for machines designed to move slowly and get big jobs done, including farm vehicles and construction vehicles designed for specialty tasks.
Fuel in motor oil
I got old ford tractor skip loader and I replaced injectors but I'm getting fuel in my motor oil
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The number one cause would most likely be leaking fuel injectors. ... When a fuelinjector is stuck open, the fuel will flood out. Gasoline will definitely get into the oil when this is the case. If the fuel pressure in your car is too high, that may cause gasoline to get into the engine oil.
Punteggio 2
3 Commenti:
I put new injectors how can they. Be stuck and I took them out not one was wet
da
There's no way it can be injectors that's why I'm asking you all
da
Read the rest of my answer.
da
Aggiungi la tua risposta
Victor Puentesjr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 193
