Salta al contenuto principale
Informazioni sulla riparazione per tutto ciò che mantiene l'esterno di casa tua ben curato.
20 Domande Visualizza tutte
Electric pressure washer is pulsing forever when handle is released
Hi!
My power washer (Michelin MPX1900) is having this issue :
1) When I pull the handle and use it to wash, it works fine, strong and steady pressure
2) As soon as I release the handle, the pump just goes “womm womm womm womm womm womm”. It just builds pressure every second and loop forever. I have to turn it off when I release the handle for more than 2-3 seconds because the noise is annoying and I feel like it’s going to break at some point.
3) There is ALWAYS water coming out of the end of the gun when the handle is released. It is low pressure water and the flow is steady (there is no difference if the motor is pulsing or if the switch is “off”). Should there always be water coming out?
Do you guys have any idea?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi vizi0n ******- this experiences persistent pulsing even after releasing the handle. This issue might stem from a faulty pressure sensor, a clogged nozzle, or an inadequate water supply. To troubleshoot, ensure the nozzle is clear, the water source is steady, and check for any sensor malfunctions. If problems persist, consulting the user manual or reaching out to Michelin's customer support can provide further assistance in resolving this pulsing matter. Regular maintenance and proper handling can help prevent such issues and ensure optimal performance of the pressure washer
Sources for further reading: https://www.pressurwasher.com/blog/power...
Punteggio 0
Aggiungi la tua risposta
vizi0n sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 80
