Salta al contenuto principale
Informazioni e guide di riparazione per i modelli MacBook Pro con display da 13".
9741 Domande Visualizza tutte
Spilt drink on it but I don't see any water damage
I split a drink on my MacBook Pro and it won’t turn on I opened it up thinking it was the logic board but it has no water damage. When I disconnect the battery and plug it in the green power light comes on but the computer does not turn on. I have no idea what is wrong how should I troubleshoot.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Where did the water enter and exactly which machine do you have?
da
I have the 2015 model and it was spilt on the keyboard
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I had this problem too on my mid 2012 macbook pro, i did as you did opened it up and tried to dry it up but is would boot up, so i tried a few things but by disconnecting the keyboard from the motherboard, my computer successfully booted up via external keyboard. Try this.
i hope this helps
Punteggio 1
2 Commenti:
Ok I will try it thank you
da
This worked thank you
da
Aggiungi la tua risposta
Brendan O'Rourk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 40
