Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
USB device not recognized/device malfunctioned.
I first noticed this problem a few days ago when trying to download some pictures of my phone. Every time I plugged it in I got the message "USB device not recognized "so I stopped trying and today my phone died so I plugged it to my wall charger, came back hours later turned it on and it showed low battery and died and when I pluged it into my computer it still showed that message and when I clicked the message it showed that "the device malfunctioned" and that "there are no drivers installed for this device" I thought it was the cable sadly that wasn’t the case some people say it’s the battery but I think it might be the dock connector that’s bad since the device is not being recognized on many computers and with different cables.
Does anyone know whats wrong?Please Help.
Questa è una buona domanda?
Punteggio -1
4 Commenti
its definitely the phone, its not the cable or the pc/mac, please write something if you've found a solution as i have the same problem and its friving me nuts almost threw the 3gs in the garbage
da
I have same problem with my Iphone 3gs....... will somebody please tell me how to get out of it....
da
I am having the sme problem ..My data cable is fine i have checked othere iphones ...
My phone charges fine with the wall charger ...
but it dosent charge via USB on my laptop as it is not recognized ..
i have opened my iphone a few days back and removed the connector that connects to motherboard of the iphone to the dock connector ..i think i have not properly applied it back ...will chk again ..
da
I have the same issue. I thought I could solve the issue by doing a hard reset- big mistake. Now I can't use my phone and it doesn't detect on the pc. I also tried replacing the dock connector. Unfortunately, I have no solution yet.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You said, "but I think it might be the dock connector that’s bad since the device is not being recognized on many computers and with different cables."
Clean the iPhone dock port, carefully blow out any dust and debris. Moisten a lint free cloth with isopropyll alcohol and carefully but thoroughly clean the dock port, especially the pins which are on top of the port mid rib.
Punteggio 1
1 Commento:
Indeed, after months of testing and experimenting I think it is a bad connector problem (on the side of iPhone device); tinkering with the cable and connector sometimes helps; also, at some point: only the original apple cable (short one) works - probably because of contact and cable resistance / impedance
da
Aggiungi la tua risposta
Sue sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 11,751
