Graphic card replacement advice
Hello everyone
My iMac has stopped working and I need to replace my Graphic Card, do you know what is a good choice for one compatible with my system?
Questa è una buona domanda?
Hello everyone
Your system came with a ATI Radeon HD 2600 Pro with 256 MB VRAM - Apple P/N 661-4426
Sadly you really can’t use anything else as the version of MXM interface your system has won’t support any of the newer boards.
This is what your board looks like
Is it available still? Can i find it in stores?
Or this one?
The board is MXM not PCI or PCIe so none of these will work. I posted a picture of the board in my answer so you can see how different it is.
Here's one for sale TheBookYard - iMac Alu 24" ATI Radeon HD 2600, 256MB (07) This board also comes with the needed heat sink assembly.
Thank you Dan
is possible to use an OEM hd 2600 (MXM) from an acer laptop instead of original imac HD 2600?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 218
3 Commenti
Your systems specs: 24" iMac 2.8 GHz Core 2 Extreme
da Dan
Thank you Dan
da gazwan.basha
Stick to OEM specs. You will not see the BIOS with most upgrades, might be really important when troubleshooting later. Other World Computing aka MacSales.com is a great place to find just what you need if you don't use Apple store or AppleCare. No, I do not work for or own this company...
da Mark
