Salta al contenuto principale
Informazioni sulla riparazione per tutto ciò che mantiene l'esterno di casa tua ben curato.
Yard Machine - electric grass trimmer- model MTD308P-REV
How do you wind the plastic cutting cord onto the spool of the feed mechanism? There is a spool, with 2 tracks. Each track has a hole for each track’s cord to go out of. When It breaks, you tap it to have a new length feed out, but it is sticking inside the spool.
How should we load the spool to trigger this mechanism?
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from https://meta.ifixit.com/Answers.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Here is a repair guide for your trimmer.
https://rdt.prod.repairclinic.com/Repair...
Punteggio 1
Thanks for sharing the guide. It saves me a lot of time. By the way, which rechargeable electric string trimmers can you recommend to me? I found quite a lot of great options on https://homendgarden.com/best-cordless-s... and I've even chosen a few already. However, I would be interested in what string trimmers you use. Perhaps you will suggest something new to me. On the Internet, I found quite contradictory reviews about the string trimmers that I chose. I don't have any extra money right now and it will be sad if I bought an unsuitable string trimmer.
Punteggio 0
Aggiungi la tua risposta
Jim Goad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 187
