MacBook late 2009 Not powering on
So I have this MacBook (late 2009) which doesn't power on. I got it this way so I've never seen it running.
When I press the power button the cd drive spins up as there is a disc in there, the sleep light comes on and the fan comes on. That's it, no other activity even after repeated attempts to reset the smc and pram. Plugging in the charger charges the battery but turns it on instantly when it's connected. If I turn it off, 30 seconds later it will power on again.
I tested the ram sockets individually with both sticks, no difference. No beeps with no ram either.
I also removed the keyboard to rule out the top case and powered on by shorting the ribbon cable connector, same thing.
I tried removing various connectors to see if a drive or airport card was the issue, they were not.
I even tried taking the battery out and letting it "rest" for a few hours, nothing. Also does the same off the adapter only.
The guy I got it from recons the lvds socket is faulty and that is causing it but I can't see that stopping booting?
Right now I'm thinkIng new logic board but I'd rather try anything I've missed before I do that. If anyone has a suggestion I'd be glad to hear it! I'm not afraid of a soldering iron either, I have a reflow station too.
Questa è una buona domanda?
3 Commenti
I had this same type machine come in two weeks ago. It appeared to have problems with the Display Data Cable. When I moved the screen it changed the lines in the screen. Ordered a new cable from PowerBook Medic. Replaced it carefully. When finished the machine would do nothing. No tone, no noise from the drives. Had another tech redo my work in case I missed something with the same result. The logic board was not removed nor was anything to do with the power supply messed with. Wish I had a better answer for you but I wanted you to know that there may be something screwy going on with the cable and its replacement.
da mayer
Ok so I opened it up and removed the cd, but I notice with no cd in the drive it doesn't initialise. Is that normal? It still accepts and spins up discs?
da Joel
Sorry Mayer just noticed your response. That's interesting to note. Should these machines power on without that cable attached? What did you do with it in the end?
da Joel
