Salta al contenuto principale
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Domande Visualizza tutte
No chime, black screen, white light steady
Hi guys,
If iMac is off, but power is plugged in, number 1 diagnostic LED is on.
If iMac is on, no chime, fans go max, black screen, white light stays steady and number 1 and 2 diagnostic LEDs are on.
If LCD unplugged and external monitor plugged in, can't turn off, it turns right back on, once external unplugged, it turns off.
Also tried with detaching everything (add on cards, hard drive, etc.), no results.
Maybe the power supply? Hope its not the logic board....
Any ideas?
Thanks!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
Punteggio 3
5 Commenti:
Thank you for the prompt response.
What kind of tool is required for that?
Thanks.
da
Exchanging the logic board with a known good one. Remember these instructions are for an Apple tech sitting there with all the resources in the world at his fingertips.
da
Thank you, so if third LED is not on, most likely logic board.
da
Logic board or video card. I don't remember if this video card can be changed or not. I would check with these folks on a board repair: http://www.dttservice.com/imacintel.html
da
+ Good Kung Fu
da
Hi S.M.
Have you finally fixed your iMac? What is the problem?
I have an identical iMac and the same problem as yours.
Thanks.
Punteggio 0
Hi,
since it turned out the motherboard went out, I decided to not change it. For a little more I could buy a new iMac...
Punteggio 0
Aggiungi la tua risposta
s m sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,689
