Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
iMac backlight only on lowest setting (LCD panel or Inverter defect?
hey guys, I have an iMac 2011 27 inch. The problem with this iMac is that the backlight only works on the lowest setting. If I increase the brightness the screen will go black, but the desktop is working because I can see it using a flashlight. The icons and desktop is visible with a flashlight.
GPU is probably working. Using an external monitor does not have this issue.
Diagnostic LEDs 1,2,3,4 are on.
Do you guys think it is the inverter or the actual LCD backlight itself ? thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Apple Part # 661-5980A
https://www.dvwarehouse.com/661-5980-App...
$24.95
iMac Intel 27" EMC 2429 LED Driver Board Replacement
Punteggio 2
1 Commento:
Hello Mayer, I forgot to mention that I fully disassembled the LED panel and there were some bad LEDs in the backlight itself. I tested all LEDs with a multimeter in diode mode and some didn’t even light up.
da
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 151
