Salta al contenuto principale
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
110 Domande Visualizza tutte
It works but no sound
I found my chilhood N64 and it did’t work, so I cleaned it and it worked but no sound. I have checked the cables and conectors with a multimeter and they are fine. In my research to find a solution I have found that the capacitors that process the audio might need replacing and that HDMI ultra mod bypasses this problem and does the processing on its own. The HDMI mod its way too expensive for me, so my question is: wich capacitors I have to replace on the board and how do I do it without messing up my N64?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Double check the solder joints on the AV port for any cracks etc. is broke, here is the guide for the port. Check components around U1 which is your MAV-IC Digital to Analog converter (DAC) video/audio. Let us know what you find.
Punteggio 0
2 Commenti:
I have tested the continuity from the board to the end of the cable with a mutimeter, I don't think that's the problem.
da
I have the same problem and haven't been able to figure it out, about to buy a new one.
da
Aggiungi la tua risposta
machitocayo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,347
