The zipper end of my sweater jacket came off.
Can the metal end on the side which the slider is attached, be replaced?
It holds the other straight end of the zipper to prevent separating of the zipper.
Questa è una buona domanda?
Use a small safety pin. If the little loop of the zipper end is still there you can use a small safety pin put it through the loop and close it it will work just like the zipper end that came on it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 429
1 Commento
Can you post some pictures?
da Joshua Freeman
