Salta al contenuto principale
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
68 Domande Visualizza tutte
Why when my phone rings it makes my notification sound
Hi I have a Samsung J8 and my problem is that when my phone rings instead of hearing my ringtone I hear my notification sound. I tried almost everything and nothing is working so if u have a suggest can u plz help me
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
are you able to hear music/ sound when watching videos? if you aren’t able to then there could be a problem with your speaker and that will have to be replaced. if it does work then there could be something going on in your settings if you go to settings then sound you can find the setting there. If that still doesn’t fix the issue I would backup your phone then do a factory reset.
Punteggio 1
2 Commenti:
Thank you so much. The factory reset worked. Thz ❤❤❤
da
glad to hear, you're welcome.
da
Aggiungi la tua risposta
Kelaiah Latchman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 612
