Salta al contenuto principale
Guide e supporto per riparazione e smontaggio di apparecchi lavapiatti.
707 Domande Visualizza tutte
Whirlpool Dishwasher starts after keeping the door pressed manually.
Hi, I have an Ikea whirlpool dishwasher. It had a free fall door because hinge string was broken which I replaced. Now, it starts when I keep the door pressed manually. It runs for sometime even if I stop pressing the door but stops after sometime. If I presss the door again then it starts again but stops after sometime if I stop pressing the door. I already open the door and checked all the wires and everything is connected. I also cleaned the area for clogging and anything stopping the close the door properly. Could it be door latch or something else need to be replaced?
Thanks
Vikas
Questa è una buona domanda?
Punteggio 1
3 Commenti
I need your model number to be able to locate parts.
da
Hi Mayer, Thanks for your reply. It's integrated whirlpool from Ikea. I can't see actual model details. It has service no. as 854586701001 and serial no. as 990740072630.
da
See if you still have the operators manual, iy will have the model number. I can't find the correct parts without it.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
it sounds like the latch is not working like it should , when you close it the latch on the shell not the door is not pushing in the switch to turn it on , check it out ans it should have an adjustment , screws or a screw to adjust let me know
Punteggio 1
3 Commenti:
I can't see any screw for the adjustment of the latch.
da
Thanks gadget1961, you were spot on. There was some misalignment between latch and the door tilt lock. I happened perhaps when the door spring-thread was broken (which I had replaced earlier). I opened everything and checked carefully and set it back and everything is working as normal :) . Thanks a ton to give new hope !!
da
Good glad I could help . I am a maintenance super 34 years for an apt community. We fix all our appliance's and then some
da
Aggiungi la tua risposta
Vikas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 884
