Only prints 1/2 the document - Epson L360
My printer is just printing half of the document. The other half of the paper is blank.
How do I fix this?
Please Help
Questa è una buona domanda?
How do I fix this?
Please Help
The article on this website might be able to help:
https://imagescience.com.au/knowledge/my...
To sum up the article, it could be:
A messed up USB port on your computer (you can just use a different port).
A problem with Print Spooler on Windows PCs (It shows steps to reset it).
A messed up USB cable (you’d have to find out if it’s easy to get a new cable and just switch it out).
If you have a Mac resetting the print system is an option.
All credit goes to Jeremy Daalder.
Good Luck.
USB port change solved the problem of printing only few pages of a document
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,685
Can you explain a bit better what you mean here a bit more on the details would help. Does the printer report an error? Does it make a grinding noise? Did you try using a new ink cartridge if the printer told you it was low.
> Is the page not fully printed and which side is missing Left or Right or Top or Bottom?
> If its a multi page document, does the pages fully printed you're just missing a few pages?
da Dan
My printer Epson L360 printed only few pages of a document.. So I have to print a couple pages only at a time. For example for document with 10 pages, I need to print 5 times, printing 2 pages in each print. As per the reply given here, I changed USB port of the printer cable, it worked well. Thanks for the reply
da Karuppanagounder Somasundaram
