Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
MacBook Pro that shuts down without warning has now escalated
I own a
After, in April 2018 I replaced the battery with an iFixit
I started having trouble with it shutting down randomly with on battery and on charger. I retrospect I have noticed that the past several months, the battery would drain quickly. Although I was not doing anything exotic, I thought it was me. The battery shows
and
. Clicking on battery icon
. One solution was to reset the SMC, which I did. Problem still exists although it seems like it works properly with the charger plugged in. The battery being only 13 months old, I am concerned it is not the problem and reluctant to spend $70 bucks to find out (I bought the tools the last time) :-)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello
If you can reset the SMC + PRAM ok and have never spilled liquid on your machine.
I’d say your problem is the thermal paste on your cpu / gpu is dry, has dried out, as its an old machine.
And needs replacing quick i.e a good service is needed. Clean out the rear fan grills also of fluff and hairs etc.
Your machine is shutting down because it is hot. Shutting down is a safety feature.
Punteggio 0
Aggiungi la tua risposta
Pete Banks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 82
