Salta al contenuto principale
A general purpose laptop released in 2010 with a 15.6" screen.
17 Domande Visualizza tutte
No WiFi. (actually 5200 series)
Despite attempting connection via Ethernet cable to no avail as well as any other method connecting Wi-Fi, I noticed the wireless switch (the button under the screen just above the keyboard to the right of the power button) has a faint glow emanating from the LED. VERY faint. Possibly indicating a short? If it's any indication, it is when the orange LED is glowing (or lit), such as the touchpad switch on the opposite side (to the left of the power button) is No lit LED = device works… when LED is lit, devices is off, i.e. that device has no function, or is switched off. If logic and deduction make any points here, the Wi-Fi is Switched Off. After removing the panel above these switches (plastic above the keyboard) I was able to, using a thin gauge wire, jumper 2 of the contacts on opposite sides of the switch for the Wi-Fi, which NOW allowed the wireless system to now recognize Wi-Fi signals in the area, however still will not connect. Despite having going into Computer Settings and manually enabling as many Services as possible. Many of the wireless related Services simply will not start up saying that they have a dependency group failing to start. What's my next step guys?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Replace the wireless card. You don’t say exactly which model but it may be in the RAM compartment. Take a look. Centre opposite end from battery.
Let us know how it goes.
Punteggio 1
1 Commento:
Already tried that. But thanks. *Actually I misstatements the model as well, it's a 5500 series.
da
Aggiungi la tua risposta
dannerpaint sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 357
