What do I need to retrieve my data from my SSD
Hi,
I’d really appreciate your help.
Does anyone know what I need to retrieve this data from my 2016 MacBook Pro SSD? It’s from jan 2016 so is a late 2015 one I think.
Thank you very much
Update (05/20/2019)
Hi, thanks for the help.
It’s just the flash drive that I took from my laptop. Just un-screwed one screw and took it out. I was hoping to do a DIY job to save a bit of money and put it toward a new laptop. This is the laptop spec
Questa è una buona domanda?
7 Commenti
s goth machine currently running and can you access the drive or do you need to pull the drive?
da mayer
Hi, thank you for your reply. I still have the laptop but it just won’t turn on as it’s broken too badly to repair from water damage unfortunately
da Simon
Hi,
thank you very much for your reply and I can see why you are so highly rated!
I’m from England for the help wouldn’t work, but I do appreciate it.
I was hoping this would work? https://www.amazon.com/QNINE-Enclosure-M...
da Simon
Is the photo you posted your actual stick or what you believe is in it? You can also get me that exact machine make by inserting your serial number here:
https://everymac.com/ultimate-mac-lookup...
I do know of a place in the UK that might be able to do this for you but I don't want to say more until I know what you have.
da mayer
Thanks for the help guys! Tbh I’m not sure if it even works. I took it out before I sent my laptop away as I thought it would be quicker to recover the data myself, and didn’t realise it would be hard. The guy they looked at my laptop said this “Just to let you know that I won't be able to repair your MacBook for you. This is due to there being a hole on the circuit board which is causing a short to ground on one of the main power rails. I've tried to clean the area and remove this short but as it's happened near to the CPU I would image that this has also been effected.” Probably easier to bite the bullet and get a new one. It’s a great community you have here, with lots of nice people! Thanks
da Simon
Mostra altri 2 commenti
