How do you expose the lens/sensor to blow dust off?
I can open the case but how do you get the lens/sensor exposed to blow the dust off the lens and/or sensor?
Questa è una buona domanda?
You have to remove the lens assembly from the camera then open it to reach the sensor.
Thanks for the reply, but how do you remove the lens assembly and open it? Is there a procedure/exploded view? from Canon?
Canon service manuals are pretty hard to find but maybe oldturkey03 could check if he can find it ?
The only tutorial I can find is how to replace a bad LCD panel on a A590:
Se if this will help to get the lens cover off Canon PowerShot A590 IS Flash Assembly Replacement
Thanks, but this procedure does not continue to lens assembly removal/opening. Is there a continuing procedure available?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,311
