Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
The SSD Area and the DRAM Area without the protection tape
Hi, I had a situation with my MBP 2017 nTB. I’m trying to replace the screen. However I sent my MBP to a bad technical services and they removed the protective tape from the SSD area and the DRAM area. It’s ok if I leave the SSD & DRAM area without this protective tape? What do you recommend? It’s easy to get this tape? Where I can find it? What is the generic name?
Again thanks for your help. I really appreciate an answer about this!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Scotch tape works in a pinch but if not in a rush better go for yellow kapton tape as it's thin and is very good for preventing shorts. Polyimide Tape
Immagine 108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.
Prodotto
Polyimide Tape
$9.99
Punteggio 3
Aggiungi la tua risposta
flaviorrr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 125
