Salta al contenuto principale
Fotocamera digitale compatta da 4,0 megapixel di Canon.
Constant Memory Card Error
I keep getting “Memory Card Error” no matter how many cards I try. Can it be fixed? Thanks
Questa è una buona domanda?
Punteggio 2
1 Commento
Are you able format it?
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
If you are formating the cards on PC, are you using FAT32 or exFAT (or NTFS?)? You should format your card to FAT32.
Punteggio 2
4 Commenti:
Thank you so much for your help. I was formatting at the incorrect settings. Thanks again. Best news I have received in a long, long time.
Irving E. Carlson
Owner
Carlson Studios
da Condividi
da Condividi
Can someone please explain "formatting a card on PC"? I just got a new memory card from Amazon and "memory Card Error" appears with old and this new card"Tab on side is in up position. Sheila, Senior Citizen. Thank you.
da Condividi
Thank you for share with us.
da Condividi
Aggiungi la tua risposta
Irving Carlson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 5
Ultimi 30 giorni: 27
Tutti i Tempi: 632
